Design and Weight Optimization of Aluminum Alloy Wheel
SouravDas0306
SouravDas0306
edited April 2022 in Altair HyperWorks
This paper deals with the design of aluminum alloy wheel for automobile application which is carried out paying
special reference to optimization of the mass of the wheel.
Till now this article has received 41 citations throughout the world.
The Finite Element analysis shows that the optimized mass of the wheel rim could be reduced to around 50% as compared to the
existing solid disc type Al alloy wheel. The FE analysis shows that the stress generated in the optimized component is well below the actual yield stress of the Al alloy. The Fatigue life estimation by finite element analysis, under radial fatigue load condition, is carried out to analyze the stress distribution and resulted in displacement in the alloy wheels. The S-N curve of the component depicts that the endurance limit is 90 MPa which is well below the yield stress of the material and safe for the application. The FE analysis indicated that even after a fatigue cycle of 1020, the damage on the wheel is found only 0.2%.
Welcome!
Welcome!
