I trying to create a case block to change parameters for different situations (about 130 case), but I have two troubles.
1.Cannot add input connector to case
2. code gen-> compile or Go simulation, It shows the below error window as below picture.
Thanks.
Hi Robbert ,
1. Case block doesnt allow you to add beyond 125 input pins. Alternatively to resolve the issue you could use map block instead of case block.
2. If you select default case on the case block you will be able to run the diagram with 125 input pins. But I suggest you to use map block instead . Attached the example and txt file.
Girish
