A brief description about the project:
There is a clip which should passes through the sheet metal slot. The clip is made of plastic. We are looking for the the required force
Case#1 straight installation force
Case#2 Straight removal force
Which means that the displacement is known and We are looking for the required force
Unloaded condition of clip (Below is the initial state, before clip is deflected as it passes through the sheet metal slot)
Case#1
The leafscreen is pressed into the sheet metal so that the barb of the clip passes through the slot. Need to know max load for clip to deflect and slip into sheet metal slot for all iterations.
