I have problem I cannot see stress when I click note and enter node text {entity.contour_val} it appear N/A. However, I have simulated successfully. Thank you in advance
Try it on the element instead. Stress is on the element in the results file.
Or turn on some type of averaging and you can then query stress at a node.
