I want to use a mosfet model (.xml file) provided by a manufacturer at PSIM. How can I do that wiithout creating a new model by hand?
Please click "File >> Open Device File", then, browse for your xml file.
Please be aware, the xml file in manufacturer's website may be the model for PLECS, not of PSIM.
Although both models are xml file, they are different inside.
point to folder locations with xml files. with options->set path
either add files to these folders or create your own folder and put them there adding the path.
