Hi Team,
One of the views in this schema is displaying incorrectly - VWM_EXPRN_CONSSUMM_PREMIUMDELPHI is displayed as VWM_EXPRN_CONSSUMM_PREMIUMDELPHT (the final character is different). This means that the view cannot be opened in WPS and is causing confusion for analytics co-workers. This misnamed file cannot be used or viewed, although running code with the correct name results in a successful read in.
The schema has been checked by the iData team, and the views there are named correctly - there is a disconnect between what co-workers can see in WPS compared to the data views that are created.
Could you please help how to change the view name in wps.
Thanks
Krishna
