AUTHOR(S)
A. Hassanpour, A.G. Stavrou, C. Hare, C. Wu
SOURCE
Chemical Engineering Science
ABSTRACT
Ball indentation is a technique capable of assessing powder flowability down to very low consolidation stresses (≤1 kPa). With this method, powder flowability is determined by measuring the hardness of a powder bed, which allows the unconfined yield strength to be inferred via the constraint factor. The latter is well established for continuum materials, whereas for particulate systems its dependency on stress level and powder properties is not well defined. This work investigates these factors by simulating the ball indentation method using DEM. The constraint factor is shown to be independent of pre-consolidation stress. Constraint factor generally increases with interface energy for relatively cohesionless powders, though not for cohesive powders. An increase in plastic yield stress leads to a decrease in the constraint factor. Increasing the coefficient of interparticle static friction reduces the constraint factor, while increasing the coefficient of inter-particle rolling friction significantly increases the constraint factor.
KEYWORDS
Ball indentation, DEM modelling, Low consolidation stresses, powder flowability, Shear cell
