Hallo, I have created a laminate on the sheet.I try to use z0 and Ipos to change the position of laminat, but it did not work. Please someone tell me how to change this laminat. Thanks!
Hi
Is it the case that in HyperMesh you cannot see the laminate offset form the mid surface reference?
Or is the case, for instance, you checked with bending analysis and the bending stiffness is lower than expected ?
Regards
