Lets take a look at some of the important new and improved capabilities in the new HyperMesh user interface
Design Explorer
Design Explorer enables you to explore, understand, and improve your system's designs using methods such as design-of-experiments and optimization. By using Design Explorer, you can make better decisions and optimize the performance, reliability, and robustness of your systems.
https://www.youtube.com/watch?v=P7yADt0g7QQ
Skeleton Modeling for Reduced order modeling
Skeleton modeling is an industry independent method of creating a reduced ordered model to facilitate optimization at the concept phase. Skeleton Modeling can be used for a variety of modeling needs including purely for model build purposes and/or for concept optimization. A skeleton model can be derived from several different sources. The most common sources are donor FE and CAD geometry.
https://www.youtube.com/watch?v=VInobMmNRA0
Design Space for Topology Optimization
Create design spaces for BIW Architecture topology optimization.
https://www.youtube.com/watch?v=T8YXALm5vMQ
Section Libraries
The automotive focused section library promotes rapid creation of full vehicle architecture concept models. Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
https://www.youtube.com/watch?v=xs7DHDaeVtw
Model Reconstruction
Go from a simplified to a detailed model using lofted surfaces.
https://www.youtube.com/watch?v=5wJGD8gKvAo
Rapid Part Creation
Rapidly create parts like Bulkheads, Doublers.
https://www.youtube.com/watch?v=Hp5U9E8MooY
Symmetry and Axisymmetry
Symmetry visualization allows partially modeled geometry to be shown in full extent by reflection and/or duplication or in the case of axisymmetric models, by 3D geometry generation.
https://www.youtube.com/watch?v=4y0iqjOKUaE
Sketch
Create and edit 2D parametric sketch geometry
https://www.youtube.com/watch?v=vN4cMQV9gzY
Using the Sketcher for Beam Modeling
Using the sketcher you are now able to create and edit beam sections.
https://www.youtube.com/watch?v=DHbrpG66jqQ
FE Geometry
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
https://www.youtube.com/watch?v=ovU-xI0Uojg
Post Processing of Simulation Results
Seamlessly process solver native results in HyperMesh.
https://www.youtube.com/watch?v=0__5TRMmLM4
Aerospace Connectors
Connectors define which parts of a model have to be fastened to each other and how the connections have to be performed.
https://www.youtube.com/watch?v=htGIvknUYmc
Morphing
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality.
https://www.youtube.com/watch?v=ubuH8D2DrmI
Return to the User Migration Blog
