Hallo, I try to simulate a compress test with Material law 25. I add the failure_chang model to define the compressive strength in two directions. But it did not work. When I change the compressive strength values, the result (max. Force) is always the same. please someone tell me, where is the Error.
another question。
When I only change the compressive velocity, the result (max. Force) will be changed. This confuses me.
