Dear all, I created a cross section to export tensile forces. but there is an Error---VECTORS DEFINING SKEW ARE COLINEAR. Please someone tell me how to correct. Thanks!
Hi
You Need to define the N1,N2 and N3 to have the local coordinate system when using /SECT/PARAL
you could add for instance in the /NODE
/NODE
1001 25.0 115.0 -1.0 1002 25.0 115.0 1.0 1003 0.0 115.0 -1.0
and on /SECT/PARAL
I hope this helps
Regards
Hi You Need to define the N1,N2 and N3 to have the local coordinate system when using /SECT/PARAL you could add for instance in the /NODE #-------------------- /NODE 1001 25.0 115.0 -1.0 1002 25.0 115.0 1.0 1003 0.0 115.0 -1.0 #--- and on /SECT/PARAL I hope this helps Regards
Ok.Thanks. I have done!
