1. Introduction
Iris dataset is one of the most famous basic dataset for machine learning. This is a test of RapidMiner's Auto Model Clustering. The data includes 50 each for setosa, versicolor, and virginica, for a total of 150.
https://www.embedded-robotics.com/iris-dataset-classification/
2. Clustering
Select Clusters after load data in RapidMiner's Auto Model
Select Input variables.
Set 3 for Number of Clusters
The result shows proper classfication.
Cluster Tree shows the main differences between the clusters.
Centroid Chart shows the values for the cluster centroids in a parallel chart.
Scatter Plot displays a scatter plot in terms of the two most important Attributes.
3. Conclusion
RapidMiner Clusters worked well. The clusters almost coincides with the original classification.
