Hi
To restart Radioss job you need to have the *.rst files (restart files) from the previous engine run.
With the *.rst and the new engine fiel (e.g. filename_0002.rad, if this is the 2nd engine run) you can restart the analysis
The process on PBS depends on how it is set to copy/move files, but basically you will need to have the rst's and engine on same location and on the run option you select to 'run engine'.
I hope this is helpful
Regards
