The Session began with a brief overview of Replacing Data Sources in DPS and Monarch Server{Automator} Connection Definitions.
The Session began with our Expert reviewing the following:
Highlighted instances when data sources might be absent or relocated, and situations where sharing a workspace with a colleague could lead to the unavailability of the original file. Also discussed the process of applying updates in such cases as necessary.
Explained how to update or replace files with new data. In such cases, one can simply drag and drop the desired report onto the load plan or table. This action will add the new report while allowing you to remove the older report from the process.
Also, explained how to add files with the function Load Plan by the "Add a report" feature.
Explained how the Apply To function can change the Sheet Name.
If working with a Worksheet - you can edit the SHEET Name – and the only way to tell is if you have a metadata column that is listing the sheet name.
Chris reviewed how to create a new Database connection and how to view and select tables from this data source.
For looking at more tables, use the EDIT TABLE INFO and select/change the database and then select/change the table from the listing.
It is important to note that one must have right permissions to access Connection Definitions and Admin rights. This allows Admins to have a shortcut to connect to the sources in that you can enter in the credentials and that does not require end-users to use it.
Showed how to create a new Connection
1.- Add name.
2.- Use the connection string.
3.- Enter user ID, password and test connection.
4.-
Additional Resources:
Monarch Learning Guide Monarch v.2023 Quick Start Help with Connections Help with Replace Data
