Fixed Time Point output with NLOUT using HyperMesh OptiStruct
Updated by Vinaykumar Dhangar_21062
Fixed Time Point in NLOUT using HyperMesh OptiStruct
1. NLOUT Card definition
- Controls the incremental result output for Nonlinear Implicit Analysis
- The NLOUT Bulk Data Entry defines incremental result output parameters for Nonlinear Implicit Analysis
Where,
2.Fixed Time Point in NLOUT
2.1 Create the time Points
- Click on Analysis on Menu panel > Entity set.
- Provide the name and set card image as SET_TIME
- Click on Create > card edit
- Set the Number of time points > Define the Time points > return.
2.3 Create NLOUT load Collector
- Go to Model Browser
- Right click > Create > Load Collector.
- Provide the required name.
- Select Card image as NLOUT.
- Set Nonlinear incremental output as TIME.
- Define the SET_TIME_ID as SET_TIME
- Set SVNONCNV Yes.
Note:
- NLOUT Controls the incremental results for Small displacement and Large displacement.
- It defines the set of time points at which the incremental nonlinear output is requested.
3.Frequency in NLOUT
3.1 Create NLOUT load Collector
- Set Nonlinear incremental output as FREQ.
- Define “n”
- Set SVNONCNV Yes.
Note:
- If FREQ is set to “n”, then every n’th load level is saved for output.
3.2 Define Control Cards
- Define the following cards
- PARAM, CHECKEL,NO
Solver will not check for the element Quality
- PARAM, UNSYMSLV,YES
Use for Un-symmetric terms in tangential stiffness matrix due to friction or frictional contact problem.
4.Load step and results
4.1 OUTPUT Request
Define the Following Output Request in Subcase Options.
- CONTF
Output for Contact force
- DISPLACEMET
Output for Displacement.
- SPCFORCE
Single-point force of constraint vector output
- STRESS
Output for Stress.
5.Create Load step for NLSTAT
- Right click > Create > Load Step as Zero Clearance.
- Define Analysis Type as Non-Linear static.
- Define SPC.
- Define NLPARM.
- Define NLOUT.
- Define CNTSTB load collector.
- Run the model using OptiStruct.
6.Results
6.1 Displacement
6.2 Stress
Comments
No comments on this post.
