[23:13:24] (INFO): ************************************************************************
[23:13:24] (INFO): ** **
[23:13:24] (INFO): ** Altair PhysicsAI 2022.3.0.24 **
[23:13:24] (INFO): ** Advanced Machine Learning Software **
[23:13:24] (INFO): ** from Altair Engineering, Inc. **
[23:13:24] (INFO): ** Build: 2514318 **
[23:13:24] (INFO): ** COPYRIGHT (C) 1996-2020 Altair Engineering, Inc. **
[23:13:24] (INFO): ** All Rights Reserved. Copyright notice does not imply publication. **
[23:13:24] (INFO): ** Contains trade secrets of Altair Engineering, Inc. **
[23:13:24] (INFO): ** Decompilation or disassembly of this software strictly prohibited. **
[23:13:24] (INFO):
[23:13:24] (INFO): --------------------------------------------------------------------------------------------------
[23:13:24] (INFO): 1. Building features and labels
[23:13:24] (ERROR): No valid elements in file:
/SyfqBaha/PhysicsAi/Cyclinder/cylinder49.h3d. Only shell elements are supported.
[23:13:24] (ERROR): *** INTERNAL PROGRAMMING ERROR ***
I encountered an error while using Altair PhysicsAI 2022.3.0.24 from Altair Engineering, Inc. during model training process. The error message states: "No valid elements in file:
/SyfqBaha/PhysicsAi/Cyclinder/cylinder49.h3d. Only shell elements are supported."
The software that i used to build the shell is using altair inspire and the steps are:
1. sketch circle diameter 100mm
2. extrude then select surface 200mm
3. at property editor change the thickness into 5mm
4. apply force and support
5. run analysis
6. extract h3d file
I'm unsure about the cause of this error and how to resolve it. Has anyone else experienced a similar issue with Altair PhysicsAI? Are there any suggestions or workarounds to overcome this problem? Any help would be greatly appreciated. Thank you in advance!
