Transient thermal analysis
Gabriele Piscopo
Gabriele Piscopo Altair Community Member
edited April 2021 in Community Q&A
Dear all,
I'm trying to perform a transient thermal analysis with Optistruct.
I have a component with a constant thermal flux. On this component I have also convection on a surface and a fixed temperature on another surface (like in the attached figure 'Problem description').
Here a brief description of the modelling phases:
  • the ambient temperature for the convection element was modelled as SPC
  • The heat flux was modelled using TLOAD1 card
  • the initial temperature as TEMPD.
Firstly I try to simulate the model without the temperature boundary (Imposed temperature in the figure) and it works well. Then, I try to add also this boundary but it does not work. I imposed the temperature in the load collector containing the ambient temperature of convective element.
Where am I wrong? does this problem make sense? (I think that the initial temperature goes in contrast with the imposed temperature)
Thanks a lot,
Gabriele
  • Gildas_GUILLY
    Gildas_GUILLY
    edited April 2021
    Hello Gabrielle,
    Do you impose a 0K (or 0°C depending on your reference) to the nodes where you want to set the temperature (on the face and on the fluid), or is it a value different to 0 ?
    If different to 0, a simple SPC will not be enough, and you will need to define SPCD+TLOAD1.
    This is the way to do your problem the "cleaner" way (meaning the way that will work for all scenarios) :
    • Boundary conditions : Use a load collector to store SPC on all nodes you are going to impose the temperature (meaning the fluid node and the nodes on the constant face).
    • For the face with constant temperature :
      • A load collector containing SPCD with a value of 1 (unitary) on all nodes of the face
      • A curve (with TABLED1 card image) defining the temperature over time for the face
      • A TLOAD1 locad collector to define the dynamic loading, combining the 2 load collector above.
    • For the convection :
      • A load collector containing SPCD with a value of 1 (unitary) on your fluid node
      • A curve (with TABLED1 card image) defining the temperature over time for the fluid
    • For the flux:
      • A load collector containing the flux load on the faces
      • A curve (with TABLED1 card image) defining the evolution of the flux over time.
    • And finally you need a DLOAD loadcollector to combine your 3 TLOADs, and to be called by your loadstep.
    Gildas
  • Gabriele Piscopo
    edited April 2021
    Hello Gabrielle,
    • For the flux:
    Gildas
    Dear Guilly,
    thanks for the reply.
    after modelling the problem with your suggestions I  obtained the following error...
    See next message about line 9688378 from file:
    D:/ASTER/analisi termica/tip_altair_forum/test_flusso_temperatura.fem
    "DLOAD 10 1.0 2 1.0 7 1.0 9"
    *** ERROR # 1000 *** in the input data:
    Incorrect data in field # 3.
    Do you know why? It could depend on 'Type' (figure attached)?
    Thanks a lot,
    Gabriele
  • Gildas_GUILLY
    Gildas_GUILLY
    edited April 2021
    Dear Guilly,
    Thanks a lot,
    Gabriele
    Gabrielle,
    It looks like you forgot to enter a value for S in the definition of the DLOAD load collector.
    Gildas
  • Gabriele Piscopo
    edited April 2021
    Gabrielle,
    Gildas
    I'm sorry but now i have another error:
    A fatal error has been detected during input processing:
    *** ERROR 14: Missing EXCITEID # 6 referenced by TLOAD1_TEMP # 6.
  • Gildas_GUILLY
    Gildas_GUILLY
    edited April 2021
    As explained in the error message, you either have forgotten to enter the EXCITEDID in the TLOAD, or you have used a wrong loadcollector/load TYPE association.
    For your 3 TLOAD, the TYPE should be DISP for the first 2, LOAD for the third one.
    Gildas
