Hi All.
I'm running a spray coating simulation in the EDEM2022.3 and aim to get the intra-particle variation. I have set the simulation deck using polyhedral particles and run the simulation for sufficient time, when it comes to analyzing the spray coating the result doesn't show up in the window and the calculation console window shows different errors and failed actions, I don't know what is the error, would you interpret the massages of the console window?
attached below:
Thank You
Regards
Salma
