How to setup wear analysis in optistruct.
Hello everyone. How to set up wear analysis in optistruct. I see in ver 2023 already can calculator wear in the result. but I don't see any posts or guides.
In my example, I want to set up wear analysis in hypermesh 2024 with Sovler optistruct 2024, and the case about a tube rotating through a bearing. I don't know how to set parameters like wear coefficient, hardness, and exponents.... card image...
Thanks for your opinion.
Best Answer
Eddy _20769 said:
Thanks, Mr Rajashri,
I have read the blog, but it does not show the things I need. I want to know how to set up contact, material, and card images to have the wear results.Hi Eddy,
Attached is the example file.
You can see in CONTACT the wear parameters are defined like below.
CONTACT 1 0.1 1 2
+ N2S CONSLI
+ WEAR0.000001 1. 1.6243 0.5
$This is not yet supported in hypermesh GUI, so you can edit only in .fem file as text.
Thanks
Rajashri
2
Hi Eddy,
You can refer the below blog to know on wear analysis.
Thanks
Rajashri
0 -
Rajashri Saha_20525 said:
Hi Eddy,
Thanks
Rajashri
I have read the blog, but it does not show the things I need. I want to know how to set up contact, material, and card images to have the wear results.0 -
CONTACT 1 0.1 1 2
+ N2S CONSLI
Thanks
Rajashri
2 -
Hi Eddy,
CONTACT 1 0.1 1 2
+ N2S CONSLI
Thanks
Rajashri
That helps a lot.0 -
That helps a lot.Hi Eddy,
Can you mark the answer as correct so that it will update the status to Solved?
Thanks
Rajashri
1
