Good Morning
Im performing a fatigue analysis to a femoral stem in Ti-6al-4V and CoCr alloy, i need to calculate the Factor of safety of the stem under cyclic loading but when i select FOS the program need as an input the TFL and HSS. I dont know this properties for the materials, im also trying to use hyperlife and perform the FOS analysis, but when y try to change the material it does not let me.
Theres no other way to calculate the factor of safety without this parameters?
Thanks for your collaboration
Best regards
Ivan
