Dear Community,
I want to check if the following problem can be solve in a smart way: 7 different laminates (Lam) according to 7 properties are defined.
Now, the assembly has many components with different laminate combinations:
Component 1: Lam1+Lam3+Lam4
Component 2: Lam2+Lam3+Lam7
Component 3: Lam2+Lam5
... and so on... (43 Components
Is it really nessecary to define a laminate for each component or can I keep the defined laminates and combine them somehow?
As allways, I would be exrtemly grateful if you could help me here!
Best wishes
Torsten
