Hello, I am following the DC motor example in flux to understand how to create the circuit with a commutator and brushes. In the example, we have a lap winding with 12 slots (2-layer winding) and four poles. The macro results in 24 coils all coil regions have a positive orientation of the current each coil is apparently the positive and the negative polarity going to each segment, and because I see each coil has half the resistance value, I assumed the two coils try to model one real coil. I do not know why it does not use only one coil instead of two with the positive and negative orientation of the current. I want to understand the circuit in order to create new ones. I saw all the help and it was not helpful. Please advise.
