If you have data stored in a Snowflake database, you can connect using the ODBC driver for Snowflake. To install the connection software you need to:
- Download and install the Snowflake ODBC driver (.tar.gz) from the Snowflake client repository. SLC currently supports only 64-bit versions from 2.21.5.
- Once the file is downloaded, change directory (cd) to the /opt folder and extract the contents using the following command:
tar xzf download-path/snowflake_linux_version.tar.gz
- Where download path is the absolute path to the download location, and version is the downloaded version of the Snowflake ODBC driver.
- When complete, the Snowflake ODBC driver archive is unpacked into the /opt folder
- Add the Snowflake libraries to the shared library cache, to do this:
- Change directory (cd) to the /etc folder.
- View the contents of the ld.so.conf file.
- If ld.so.conf references a separate folder through an include statement:
Create a file called slc.conf in that folder, and add the line /opt/snowflake_odbc/lib to the slc.conf file. - If ld.so.conf contains a list of folders:
Add the line /opt/snowflake_odbc/lib to the file. - Run ldconfig.
- Include the data source name (DSN) information in the ODBC files. The unixODBC installation adds the files /etc/odbc.ini and /etc/odbcinst.ini to your system, if the files do not exist.
- Add the following lines to /etc/odbc.ini:
[Snowflake] Description=SnowflakeDB Driver=SnowflakeDSIIDriver Locale=en-US SERVER=server-name schema=schema-name PORT=port-number SSL=on ACCOUNT=account-name WAREHOUSE=warehouse-name Database=database-name
- Add the following lines to /etc/odbcinst.ini:
[SnowflakeDSIIDriver]
APILevel=1
ConnectFunctions=YYY
Description=Snowflake DSII
Driver=/opt/snowflake_odbc/lib/libSnowflake.so
DriverODBCVer=driver-version
SQLLevel=1
UsageCount=1
Where you replace driver-version with your corresponding driver version.
- Once the driver has been installed, test the database connectivity with the following SAS language program:
LIBNAME DATASRC SNOWFLAKE USER=user-name PASSWORD=password ACCOUNT=account-id WAREHOUSE=warehouse-name SCHEMA=schema-name DATABASE=dbase;
PROC DATASETS LIBRARY=DATASRC; RUN;
- In the LIBNAME statement, replace user-name and password with your user name and password for the Snowflake account-id server. Replace dbase with the name of the Snowflake database, schema-name with the database schema, and warehouse-name with the warehouse hosting the Snowflake database.
- The DATASETS procedure returns the names of all tables in the selected database; for databases with large numbers of tables, this program might take some time to run.
