Couldn't able to open Simlab. Pop-up window shows 'The required environment variable HW_UNITY_ROOTDIR was not set.'
Tried with changing environmental variables, but same issue.
Any possible solutions are welcome
It is better to uninstall and install it again.
TO narrow down the issue, please let us know the simlab version that you have installed and platform windows / Linux version
Thanks kamalraj
The issue is sorted. If we pin the simlab to taskbar, we are getting the above mentioned error message.
In all other ways of opening the tool, it is opening fine. No reinstall required.
I am working in SL 19.1 , windows platform.
Hi Rakesh,
thanks for details. We will fix this.
Thanks & Regards
KamalRaj
Senior Application Engineer – SimLab
Altair | Nasdaq: ALTR
kamalraj.rajagopal@altair.com | altair.comConnect with us: LinkedIn | Twitter | Facebook
