Hello all I am trying to create radioss file with the help of hypercrash preprocessing tool. I am not able to apply centrifugal force using the GUI.
/LOAD/CENTRI/
can someone please help.
Thankyou
Hari Venkata Santhosh Bhatta
Hi Hari,
Can you check if there is an option to add from Control Cards in HC?
Can you please upload the model file (_0000.rad)? And please tell the rotational velocity also.
Hello Prakash and George, I have explored Hypercrash a little more and discovered that centrifugal force is given in LOAD_VELOCITY_FIELD under Loadcase. Thankyou for your Time
Valeo India Pvt. Ltd.
Thanks for the update.
