This video introduces PSIM's embedded code generation for the Delfino F2837x DSP from Texas Instruments using the LaunchXL-F28379D. The workflow presented in this video is applicable to all other embedded targets that PSIM supports. Learn to:
 - setup the embedded code gen simulation
 - generate a complimentary pair PWM waveform
 - import the project into CCS
 - load the program
 - modify the program
 - setup SCI communications and connect with the PSIM DSP Oscilloscope
 - control the duty cycle from the SCI
https://www.youtube.com/watch?v=uL3JpALXORM
