Follow a step-by-step guide to modeling and analyzing a 3D frame structure in S-FRAME.
Use the framework generator to generate a 3D frame based on specified dimensions, floors, and bays.
- Define supports
- Assign material section properties to selected members - columns or beams
- Apply panel elements and area loads
- Define load case combinations
- Run an analysis
- View Results: Reaction forces, Axial member forces, shear and moment diagrams, deflections, and more
A follow-up tutorial video demonstrates how to design and optimize the structural steel members using S-STEEL.
