I'm using HW13. I could't find load step option for Radioss block 120 solver. Please tell me how can I perform nonlinear analysis with radioss.
Hi Ram,
I can see two things here, in the title it is bulk format and in the question it is block format. In case of bulk format loadstep is avaliable in the analysis radio button available at bottom right side. In case of block format, there is no such load step definition as in bulk format. You need to use boundary conditions tab in the utility page and then apply the constraints and load there itself. Then apply engine cards and run the simulation. You can got through the tutorials of radioss for the same.
