How to create Rigid to rigid contact in radioss? Is it possible with out interferences?
Hi Ram,
You can use TYPE6 contact interface to model impact between two rigid surfaces.
it is not working properly for gravity loads.
could you share some snapshot of your model where you are considering this scenario?
Regards
Rahul R
it is working for small analysis but for complex structures it is not. is it problem with force vs penetration curve?
could you share us what error you are getting for complex structure?(Out File)
i'm getting no error but interference is failing. it is for applying more gravity force
Check contact parameter.If possible share input Deck?
can you try with Type 3 interface and let us know.
If problem persist, please share the deck
How are you defining the rigids?
Can you share the model file?
