Is it possible to connect rigid material body mesh to normal material mesh with out connectors.
Hi RamF,
Do you mean with contacts?
Check with type2 contact interface if that helps
No sir direct mesh connection. if there is mesh can i apply two material for two halves.
yes its possible.In Fe it is possible but in real life it would be connected by means of connectors.
Regards
Rahul R
