Can somebody explain the details about optistruct algorithms
1. MFD
2. SQP
3. DUAL
4. DUAL2
5. BIGOPT
which is most preferable for respective type of optimization like topology, topography, free size and shape.
This info is found in the Help, as attached.
/profile/97129-adriano-a-koga/?do=hovercard' data-mentionid='97129' href='<___base_url___>/profile/97129-adriano-a-koga/' rel=''>@Adriano A. Koga
Which algorithm is used in the case of a combined optimization (e.g., topology + size optimization)? Are they solved separately using different algorithms?
this is a good question. I can't tell for sure, but i believe when topology is active, then its algorithms will prevail, due to the number of desvars.
