I am doing a modal analysis on a structure with lumped masses in the system. As I have not assigned any MOI for these masses , in modal results I can see a significant displacement of the lumped masses attached via rbe3 and thus the results seems to be irrelevant. If I do not have the MOI for the masses, can we go for adding high inertia values to restrict those displacements. Is the methodology correct?
Kindle let me know.
