I am trying to model a bus with suspension for static load cases involving enforced displacement at wheels and gravity. I have modelled the control arms and various links with CBEAM element and assigned an approximate cross-section with respect to the physical shapes.Weight adjustment for various links is done by using CONM2 element. Bushings are modelled with CBUSH elements . Spring is modelled with CBUSH and given property of PBUSHT . How to provide the spring curve in the TABLED1 format for PBUSHT. Any sample curve if available kindly provide and also let me know about the approach of modelling being selected here.
Thank you.
