Example 14 - Truck with Flexible Body
gopal_rathore
Altair Community Member
Hi @George P JohnsonI was trying to use the truck FEA model available model in Example -14.(truck with flexible body), for a crash run but it seems the model is not connected properly.
I ran the model and saw that the rear suspension assembly is not intact with chassis
Kindly let me know if you have update deck file of it
Thank you
Hi Gopal,
I don't see any issues related is reported for this model.
Can you please share a gif recording of the same showing the problem you can facing.
0 -
Hi Gopal,
I checked for this internally and as you noticed there are some modelling issues with this example file.
Most probably this will be fixed in 2018 update.
0 -
Thank you for update
