I am facing issue in opening T01 fiile of a run.
it is saying ' Unable to recognise . T01 file.
I have tried by renaming also, it did not work.
Is this due to file getting corrupted?. How can this be avoided
Hi Gopal,
Can you share the T01 file with us?
File has been sent
Kindly check
I am able to reproduce the same at my end.
This issue is escalated to the experts team.
Thank you.
Let me know when you get an update on this
Hi @gopal_rathore
I have created an enhancement ticket for the same.
Meanwhile, you can use HGTrans to convert T01 file to another format (say .abf) and use the same in HG.
