I am getting segmentation error while exporting .hm file to radioss block 13 format
Other files are getting exported properly and only this single file is showing this error.
Kindly let me know about the same.
Hi Gopal,
Please recheck the control cards assigned in the model.Can you please share the .hm file so that we will try the same from our end.
Meanwhile please delete the settings files and try again.
Hi George,
The problem has been solved. The issue was due to no specified material curve in MAT LAW 36 material.
Thank you for your response.
