Hi ,
I am working on an assembly of solid meshed parts. Now I need to provided weld connectivity between the parts I would like to various techniques for the same. As in shell mesh node to node rigid , node equivalence, connectors are used , can we go for same methodology in 3D mesh also.
I did one trial run with node to node rigids but behaviour is not coming proper.
Thank you
