Dear All,
Currently i am working on the Impact analysis of the kevlar fiber which gets hits by bullet,while solving i got the Error as NO RESTART FILE.Kindly provide your guidelines.
Thanks
Ram
Please share the entire .out file.
Is that error is still coming? If so please share some screenshot.
Regards
Rahul R
Hi All,
I am trying to assign the material properties of kevlar fibre to the shell element of thickness .57mm
Please note that in Radioss 13.0 we have new options for LAW58.
I have attached userguide of Mat LAW58 for your refernce.
Ram,
There are no engine parameters in your model file. Please define engine parameters and check.
Dear Sir,
I have crated the engine parameters in my model which i had sent to you.
Model which you had sent is HW 13 model and i am using HW 12.0
Kindly do the needful
I have remeshed the model and reduced the model to node lessthan 10000 for compatible with HW 13.0 Students edition and solved the model in Radioss ,the model get solved but the simulation is not proper the bullet is not get fired ,it is in stable position. kindly mention the error which i had done in my model ,since i get correct it and gets run the model which was developed in HW 12.0.
There are modelling errors.
Please correct them. Contact definition is not correct and also specify the right velocity
Kindly mention the errors in my contact definition and velocity
There is no contact at all..
Please go through the tutorials available on help, like this one
Hi Prakash,
Am receiving error as , Missing 'NORMAL TERMINATION' in output file.
Can you check it..
Please check the output block defined in the model.
The error says that no variable is defined for the Rail /TH group.
Keep Num_Variables as 1 and give the variable as DEF so that all default outputs will be extracted.
Thanks for your prompt response..George..It has been solved...
