Dear Sir,
i am in requirement to do crash analysis for my model,since i am beginner to this domain kindly provide the tutorials regarding crash analysis
Thanks
Ramganesh
hi,
I am using radioss for analysis and i am working on human brain . I need to give material properties and there are too many options in radioss for material type.Please tell me what type should i go for and what card image.
Again for output file, hyper mesh 12 doesn't show engine file so i am using output block and control card. But in output block i am not able to figure out this. And even in case of control card. Please guide me through this.
Thank you.
Generally most of the analysis on the brain uses material type as elastic..although brain is visco elastic..
Hi sdjagtap
could you please let us know what are all the properties you have for the modelling?
