Dear All,
I am currently working on some static analysis of the mounting plate in which very high load is acting (approx 5000 tons) .Material used is Mild steel. I am getting displacement of 13 mm and the vonmises stress is 1200 mpa. at the constraints and some major area around 500-600 mpa. How can i conclude the design is safe or not ?
Thanks
RAM
