Dear All,
what is Autopitch tool? How to create automated connectors using this tool?
Thanks
Ram
The Autopitch tool is designed to create weld points at a predefined pitch distance.
The Autopitch tool is a dialog box with six inputs.
•The first input is the components to which you wish to automatically add connectors.
•Search distance: The distance to consider between components.
•Spot pitch distance: The distance between each connector.
•Spot pitch end offset: The distance from the end of an edge or flange to the connector.
•Distance from free edge: The distance from the free edge to the connector.
•Feature angle: The feature angle is used to segregate the model into faces that are planar within its specified value.
Thank you George, Like this can we create the automated springs or Rbody to connect the lot of components in single time ?
