This article shows in tabular format the port types supported by the Feko solution methods. This is important to know since the model construction and solution method dictate the type of port to use.
The port types in CADFEKO per solution method.
See Ports and sources in Feko for more information on ports, sources as well as practical examples on how to feed typical structures in Feko.
