Dear All,
Currently we are working in flow analysis of turbine blade on film cooling and there is a problem in assigning the different properties to different inlets in Acuconsole
Kindly provide your valuable guidelines
Thanks
Ram
If the different inlet surfaces are in separate components, then it should be easy to assign different properties (Vleocity, Mass Flux, etc) using the boundary conditions option in AcuConsole or HyperMesh.
