Dear All,
In Radioss ,how the solution time differs?
whether it depends on number of elements or the boundary conditions ??
Kindly give your suggestions
Thanks
RAM
Solution time varies based on the time step of the analysis.
check which object is responsible for the low time step (.out file). It can be an element, a node or an interface.
For an element, check the related material.There must not be an error in the units system that this data is given in. check the element size also
For a node, check the characteristics of connected elements. If the node is on the master side or the slave side of an interface, this interface must be verified.
For an interface, the gap of the interface must be verified if some failure happens on the master or the slave side of the interface.
