Closing polyNURBS holes with Edge bridge and Close Hole
ArjunA_22390
In this article we will look two commonly used tools for closing holes in PolyNURBS geometry.
- Edge Bridge
- Close Hole
Edge Bridge: Create a birdge face across two open edges.
- Select PolyNURBS object.
- Go to Edges mode (S)
- Use 'N' to toggle Nurbify (helps with complex models)
- Holding Ctrl, select two open edges
- Right click - Bridge (Alt+B)
Close Hole: Create an 'n' sided face using closed edges as input (minimum 3 edges)
- Select Close Hole tool
- Select one of the edges part of a closed loop
The attached video shows a use case with both tools.
