Composite Shuffle Optimization with plys not in 45 -45° angle
Merula_20758
Merula_20758 Altair Community Member
Hey all,
currently I am working on a composite optimization process that involves no 45 and -45° plies.
What I experienced was, that with the step 3 (shuffle optimization), optistruct did not consider my constraint of maximum ply successor. Is this a knows issue?
Additionally, why can't we define pairing constraints between other plies than the 45 and -45° ? Is there a physical reason why you would do that just with 45 and -45 ?
Thanks and best regards  :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Merula
  • Altair Forum User
    Altair Forum User
    edited February 2018
    Hi @Merula
    Could you please the .out file of shuffling part?
    Pairing 45 and -45 reduces in-plane shear stress.
  • Merula_20758
    edited November 2020
    Sure. .out attached... we noticed that the constraint was violated, so we increased it to see if it would have any results...
    I attached the .html as well for you to see what changes with every iteration...
    Unfortunatly I cant share the .fem file.
    Thanks Prakash.
  • Altair Forum User
    Altair Forum User
    Hi @Merula
    Optimization finished in two iterations and from .out file I couldn't find anything.
    Is it possible to share the model file?
  • Merula_20758
    I will create an academic example I can share, which I will send to you shortly. Thanks
  • Merula_20758
    As promised, here are the files.
  • Altair Forum User
    Altair Forum User
    Hi @Merula
    If you look at the stack after shuffling, only 0, 90 plies followed MAXSUCC rule but rest were ignored (0, 60). This is intended. The current mechanism accepts only 0/90/45/-45
    Developers are already working on in to make a more robust optimization tool.
  • Merula_20758
    Hi @Prakash Pagadala,
    as far as I understood this, maxsucc is  a constraint from manufacturing side... Why is it limited to 0 90 45 -45 ? Is there a physical reason for this or just a TODO in the feature list?
    Best regards
  • Altair Forum User
    Altair Forum User
    Well, maybe this how it was programmed at the beginning. Proposed, In next version shuffling with MAXSUCC constraint will support all angles.
  • Merula_20758
    Thanks for this clarification. Looking forward to this update.
  • Altair Forum User
    Altair Forum User
    edited November 2019
    Is this still the case in Altair 2019 (Optistruct 2019) i.e. if I have a stack with -30/30/90 plies will it ignore the MAXSUCC constraint completely and not be able to pair +/-30 plies?
