VOV: Resolve the Error "exec: vtclsh: not found"
MikeR_21368
MikeR_21368 New Altair Community Member
edited February 2023 in Altair HPCWorks
If you see the error, "exec: vtclsh: not found" while attempting to run a script from within a cron job, it is likely because the PATH is not properly set in the cron job. See the following example:
/path-to-rtda/version/hostOS/scripts/ftlm_lmproject: line 16: exec: vtclsh: not found
A regular cron job has a very restricted PATH when it is run. You will need to run it in a shell that has sourced
/path-to-rtda/version/common/etc/vovrc.sh
You can run it within the setup provided by the 'vovcrontab' command, which takes care of setting up the environment.
Welcome!
Welcome!
