I am trying to find the EFFICIENCY MAP using the FeMt tool . I am sure I have enough memory(194 GB Free) , the motor I am testing is a reluctance motor can that be the Problem ?
I think it can work with a reluctance motor but you may need to specify the rotor initial position to align phase 1 with the pole axis.
I'll make a test and let you know
I made a small test using the default reluctance machine from FluxMotor, exported it in Flux and then generated the femt component.
I managed to run the MTPV fast efficiency map correctly
