This script uses surfaces and mesh size as an input. The script will then create surface cuts parallel to the x and y axis based on the mesh size specified in order to create perfectly orthogonal mesh lines. Once the script finishes, the user will have to manually correct areas around the surface edges.
Meshing
2D Meshing
Share your models, scripts, workspaces, and more with the Altair Community.
