I'm modeling polinurbs over the result of a stiffness optimization on a pedal. I set up the simmetry costraint before running the analysis since of course the pedal needs to have a simmetric shape considering its medium plane and the results came out simmetric as expected.
Once I move to Polinurbs tho there's no way to set a similar costraint so while I'm wrapping the main body of the pedal, facets of the Wrap tool (the ones in black that you drag along the optimized body, to be clear) are not always perfectly normal to the simmetry plane therefore resulting in an asimmetric final geometry to export.
I'd have to cut in half the final geometry, eliminate one of the two halves and mirror the second but this looks rude to me and also quite difficult to do without loosing properties or resulting in an error.
I'd be very glad to have a suggestion regarding this topic
Thank you very much
